Disables an NTP broadcast client on the switch.
broadcast-client | Specifies enabling NTP broadcast client. |
vr | Specifies disabling NTP broadcast client for a VR. |
vr_name | Specifies the VR name. If a VR name is not specified, the VR of current command context is used. |
An NTP broadcast client is enabled by default.
If the broadcast client function is enabled, the system can receive broadcast-based NTP messages and process them only if a VLAN is enabled for NTP and the VLAN is active.
The following command disables an NTP broadcast client on the switch:
disable ntp broadcast client
This command was first available in ExtremeXOS 12.7.
The vr was added in ExtremeXOS 22.2.
